Re: Farmall 100 missing cylinders
Posted by Janicholson on April 24, 2011 at 20:02:54 from (67.72.98.45):
In Reply to: Farmall 100 missing cylinders posted by DW Swindall on April 24, 2011 at 07:15:28:
What I can imagine is that the engine started to misfire. You took it home and changed the components listed. By accident you replaced the plug wires in the order they appear on the block, but that order is from front to back, as read 1342, not using the rear of the engine as #1. It is clockwise at the cap from the 1:30 position clockwise, #1 then #3 then #4, then #2.
#1 is at the front (radiator end). Jim
