When you rebuilt the carb, did it run well or did you still need to run choked? If you still had to run choked I would say you have a fuel flow problem. Keep in mind the H has a gravity fuel feed system. Any blockage will hamper the amount of fuel getting to the carb. Check the fuel flow path from tank exit to carb bowl, including float level. If that is all well I would check for intake leak, i.e. loose manifold or carb. Vacuum leak someplace.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
