Posted by rustyfarmall on April 25, 2011 at 10:55:37 from (216.248.71.224):
In Reply to: Farmall front hubs posted by Gene Popkes on April 25, 2011 at 06:47:22:
Sure, a 6 bolt hub is available to replace the standard cast hub, but then the spindles are going to be the weak point. Heavy duty spindles are available, but I'm not sure those will fit the standard duty front end. To do it right, install a brand new, heavy duty Schwartz wide front, and sell your old one. The old one should be worth roughly 1/2 to 2/3 the cost of the new one.
The cost of the parts needed to rebuild what you have now and turn it into a heavy duty model will be somewhere around 1/2 the cost of the complete heavy duty wide front.
