Re: Carburetor Problems - Farmall H, have to run at half ...
Posted by Ludwig on April 25, 2011 at 14:58:45 from (198.51.119.151):
In Reply to: Carburetor Problems - Farmall H, have to run at half choke posted by diesel833 on April 24, 2011 at 19:31:36:
Have you drained all the gas out of the tank and checked for crud? Have you cleaned the strainer at the input to the carb?
Water in the gas or crud in the tank would explain cleaning several times and getting the same issue.
