Re: farmall m hydro question
Posted by CNKS on April 25, 2011 at 17:40:04 from (216.144.104.128):
In Reply to: farmall m hydro question posted by 47farmallM on April 25, 2011 at 16:58:21:
Unless you have the "christmas tree" on the right side of the tractor next to the fill plug, you have one way hydraulics. You only need one hose going to the up port in the cylinder and a bleeder valve in the other cylinder port. Power up, gravity down. Sounds like you have one of the hoses going to the down port on the cylinder. It will not work that way. You can use any one of the ports on the side of the tractor.
