Re: B275 + or - ground?
Posted by 504 on April 25, 2011 at 18:30:43 from (64.111.61.44):
In Reply to: B275 + or - ground? posted by Clint Skarovsky on April 25, 2011 at 17:57:56:
B-275 Diesel was 12 NEG ground. It had two 6v batterys in it but I switched it to two 12v.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
