here are some pics of one of my m's with the aftermarket char lynn valve, it is mounted to the rear of the fuel tank. on your belly pump, you have three outlet ports, two near the engine on either side, and one to the rear. the rear was used for the delayed lift on a mounted cultivator. there was a valve in line in the hose for the rear cylinder on the rear cultivator gang. i ran one of the front outlets on the belly pump to the "in side of the char-lynn valve, then run the return from the char-lynn valve to the drain plug on the bottom of the belly pump, using a pipe tee and use the extra side of the tee for a drain plug. now, with the control rod in the full back position, the pump is flowing fluid thru the char-lynn valve. the valve will now give you two way hydraulics. heres some pics. my email is open if you have any ??s glenn
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
