Posted by The tractor vet on April 26, 2011 at 06:26:53 from (76.212.227.102):
In Reply to: Farmall m and jd 7000 posted by cessnapilot3 on April 25, 2011 at 20:15:30:
NOPE not with 950 lbs pressure unless ya put about and 8 inch lift cylinder on the planter then you will run out of oil before the planter lifts. John Deers run higher pressure on there hyd . systems. My friends John Deere 720 D will not lift a 4 row 7000 Notill loaded with fert. as it is and old low pressure system also . As he had this bright idea that we were going to use this the 720 to plant with last year to save fuel . I tired to tell him that it would not lift it . But he just had to try . Lot of messing around till he got it thru his head that old low pressure systems will not lift heavy newer equipment.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
