Re: Farmall m and jd 7000
Posted by rustyfarmall on April 26, 2011 at 06:42:34 from (216.248.71.224):
In Reply to: Farmall m and jd 7000 posted by cessnapilot3 on April 25, 2011 at 20:15:30:
I planted quite a few acres using a fully loaded (fertilizer, insecticide, etc.) John Deere 495 behind a 1949 Farmall H. It was slow going in first gear only, but the belly pump had no trouble lifting that planter.
