Re: 574 brakes
Posted by 1468 Chris on April 26, 2011 at 12:37:21 from (199.246.2.11):
In Reply to: 574 brakes posted by TimWafer on April 26, 2011 at 11:23:41:
Your O-rings in the brake calipures are leaking. They are a pain in the a$$ to change because you have to pull the rear tire, hub, axle stub, and axle housing to get to the brake. Once appart it is an easy fix. Just did the ones on my 885. Same problem as described.
