Re: Re: Re: Re: Where can I get a radiator for a 460 farmall?
Posted by kev in iowa on July 29, 2000 at 12:21:22 from (207.177.4.100):
In Reply to: Re: Re: Re: Where can I get a radiator for a 460 farmall? posted by Rich (ks) on July 28, 2000 at 20:10:37:
The bearing sound is from the outboard end, you take the wheel off and remove 4 small bolts from the endcap. I listened to it again and the brakes do not effect it, also the sound is in time with the axel rotation. A bearing on the diferential shaft would squeak at a faster rate. This tractor sat for quite a while so the bearings might have rusted spots on them. I will proably change both seals and the one bearing.
Post A Followup
: Re: Re: Re: Re: Re: Where can I get a radiator for a 460 farmall?
