Farmall H Differential
Posted by Greg Howard on April 26, 2011 at 17:26:48 from (24.231.176.31):
I'm just beginning a Farmall H resoration and decided to start at the rear and work forward. I removed all of the bolts for the deck covering the differential and wanted to know if there was a special way this cover needs to come off so that nothing happens to the gears below. Is it just a straight pull up or something other? I have above average mechanical ability, but I'm not a mechanic if that makes sense. Unfortunatley, I may be getting out of my skill set very shortly. Thanks! Greg
