Re: Single bottom IH plow
Posted by Fawteen on April 27, 2011 at 02:34:40 from (72.65.111.25):
In Reply to: Single bottom IH plow posted by James Williams on April 26, 2011 at 19:02:59:
Sounds like you don't have your plow lined up right. The furrow wheel on the plow needs to line up with the rear wheel of the tractor.
If you have a hoop drawbar like on a letter series Farmall, pin the hitch on the plow to the right of center a couple notches.
You may also need to change the angle of the hitch on the plow itself if you can't get it to set over far enough.
