Posted by IHCPloughman on April 27, 2011 at 07:01:39 from (173.29.64.50):
In Reply to: Single bottom IH plow posted by evilboweviel on April 26, 2011 at 19:02:59:
No. That is precisely the problem. The landside holds the plow, if you give it a chance. By running the hitch too flat, you make the plow "run on its nose" and you lift the landside out of the furrow bottom. And, the share has to be sharp and have suck or else it won't work either. So many people adjust the hitch trying to compensate for a worn share, when the correct solution is to fix the share! After that, there is the possibility that the landside is worn to make it rounded on the bottom making it easier to slide out of the furrow bottom.
I admit adjusting the plow hitch so that it is left of the beam is going to add side draft that the landside has to absorb, but it should take it. I add side draft to the 2-12" plow behind my M. You adjust the plow hitch side to side only to get the correct width of cut and to make the tractor steer well. Moving the hitch to the right because the plow is pulling crooked won't fix the problem!
My advice would be to adjust the plow hitch to be as low as possible on the plow, adjust the tractor hitch to be 15-17" from the ground and go from there. If the plow won't go in the ground then, you need to work on the share.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
