Re: Busted block on 140 Farmall
Posted by Jimmy Robertson on April 27, 2011 at 07:47:23 from (76.3.93.164):
In Reply to: Re: Busted block on 140 Farmall posted by Red Farmer 84 on April 27, 2011 at 07:36:45:
Hi,
I am located in Wake Forest, NC. I have checked on some around here but they are so expensive...even the ones that look worse than mine!!!!
