Re: Why no hoop drawbar on the C?
Posted by Dave H (MI) on April 27, 2011 at 07:57:24 from (66.87.8.46):
In Reply to: Why no hoop drawbar on the C? posted by mkirsch on April 27, 2011 at 05:24:59:
The advertising materials for the C do not show the large horseshoe shaped drawbar arrangement that you find on other letter tractors. Specifically mentioned is that the smaller swinging drawbar arrangement does not have to be removed when using direct connect implements. The wording "regularly equipped" is used to describe the installation. This would indicate that there was probably an option although it is not listed in the special equipment section of the ad. Possibly this was something offered later in production as an aftermarket attachment? The ad I am reading is for the C and there could have been changes made later.
