Re: 656 gas
Posted by dhermesc on April 27, 2011 at 08:08:11 from (24.248.193.103):
In Reply to: 656 gas posted by MarkinMo2 on April 27, 2011 at 02:26:32:
If you are going to work it hard you might want to pass, when that old 6 cylinder gets put under load is does burn a lot of fuel - especially compared to the 282 used in the diesels. If you only plan on using it for light duty (haying, chores) its fine, fuel consuption drops off quite a bit. Those engines also tend to start pretty easy in the dead of winter without the need for a block heater.
