Re: Why no hoop drawbar on the C?
Posted by Jim Becker on April 27, 2011 at 08:30:22 from (173.57.144.251):
In Reply to: Why no hoop drawbar on the C? posted by mkirsch on April 27, 2011 at 05:24:59:
I don't believe IH ever offered the U-shaped drawbar for the C. As already stated, they were working closely with the concept of using direct-attach implements most of the time. If you use the C axle clamps that were needed with mowers, cultivators etc, the H or other drawbars will bolt right on. The quick-attach drawbar from a later F-12 goes right on and is heavy enough for a C.
