Re: rubber boot gear shift lever 460 Where to Buy?
Posted by pete 23 on April 27, 2011 at 10:21:02 from (74.44.100.190):
In Reply to: rubber boot gear shift lever 460 Where to Buy? posted by symour on April 26, 2011 at 21:47:32:
I never saw one on from the factory but IH did introduce them for over the counter sales on the 4 and 560 tractors. This was about the same time they changed the little funnel shaped shield on shift lever to accept an o-ring to keep water out. I modify a lot of shift levers to get an o-ring fitted on it. You have to realize the original lever breathes through a slot in that shield so when you seal it up you need to drill a hole in casting where shield protects so trans can breathe.
