Re: H trans input and countershaft seal
Posted by Theman on April 27, 2011 at 11:40:30 from (65.198.133.254):
In Reply to: H trans input and countershaft seal posted by Dan Wittek on April 27, 2011 at 11:15:45:
You have the bolt and washer removed. Good. Now put the clutch shaft (minus the wavy coupler) back up there. Place a shallow socket - I use a 1/2" drive 3/4" - between the two yoke pieces and a pair of 3/8" bolts and flat washers to pull the stuck half from the input shaft. Tighten the bolts evenly and be careful not to damage the tapered holes in the yokes.
