Re: M Farmall Lift Capacity
Posted by Rob Maloney on April 27, 2011 at 12:40:16 from (12.167.79.93):
In Reply to: Re: M Farmall Lift Capacity posted by old on April 27, 2011 at 10:52:15:
Thanks for your reply. Seems like I read in a manual that the Lift-All pump only had a capacity of 850 psi. The cylinders are small (probably 2"). Would larger cylinders command more lift, even if the pump is maxed at 850 psi? Thanks.
