Re: Farmall 200 Fast Hitch
Posted by farmallhal on April 27, 2011 at 14:06:16 from (76.4.171.41):
In Reply to: Farmall 200 Fast Hitch posted by LRRifleman on April 26, 2011 at 18:29:40:
The Super C and 200 both have small points as noted by IH Fan but you can use this implement on your 340 by using the 1/2" thick spacers under the points which fill the receivers on your 340 to the same depth as the large points. I have a pair of the spacers and can provide dimensions if needed, Hal.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
