Posted by Stemmy on April 27, 2011 at 14:44:34 from (206.49.63.193):
In Reply to: belly pump seal posted by Finnbair2020 on April 27, 2011 at 12:44:37:
its right hand thread. Ill try to make this understandable... I took a piece of keystock the same size as the one on the coupling and welded a nut in the middle of one of the sides. Take this "tool" and put it in the coupler, then take an impact gun and remove the coupler. You'll also need to take a long screwdriver to jam the gears so they dont turn when you try to remove the coupler.
then when you go to put it back on, you cant jam the gears (since your turning it the oppostie way) so it just takes a few short bursts with the impact to get it back on. Once you get it back in the tractor it will "torq" itself down.
Hope this helps. I can get a picture of my "tool" I made tomrrow and post it up if I totally confused you.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
