Re: Farmall 560 PTO
Posted by Wardner on April 27, 2011 at 15:33:07 from (209.86.226.30):
In Reply to: Farmall 560 PTO posted by Robbie Gooch on April 27, 2011 at 13:51:10:
If you replace a clutch type with a planetary, the PTO will run too slow. The IPTO driven and driving gears at front of clutch housing are different.
This is the reason you only see planetary PTOs on the 660. The higher engine speed (2400 rpm) makes it necessary to use the planetary reduction in the earlier PTO.
