Re: M Farmall Lift Capacity
Posted by Red John 2 on April 27, 2011 at 19:18:26 from (72.188.248.231):
In Reply to: M Farmall Lift Capacity posted by Rob Maloney on April 27, 2011 at 10:26:56:
Rob, I have a 3-point with two 4" cylinders on my 42 Farmall M. I can easily lift 1000 lb bale using a 2 prong bale fork. If I need to do some serious lifting, I remove the fork and install a drawbar in its place.(Do this to get closer to rear of tractor with the item being lifted). By installing a front weight frame along with weights will enable you to lift about whatever you want. Bye the way, my lift speed is plenty fast enough for me.
Oh, the 2" cylinders you have now are way too small. You will not be happy till you get larger cylinders. Tractor Supply Co. and others have them... about $100 each.
