Re: Farmall 100, touch control internally leaking
Posted by TractormanNC on April 28, 2011 at 05:00:30 from (72.251.104.235):
In Reply to: Farmall 100, touch control internally leaking posted by Patrick Martin on April 27, 2011 at 23:41:43:
Check valves that lock the pistons in place are leaking. Did you just put a seal kit in it? If so did you get the plastic check valves, their operating pistons and their sleeves put in correctly. Also, thermal relief valve might be leaking.
