Re: M Farmall Lift Capacity
Posted by mkirsch on April 28, 2011 at 05:23:28 from (64.80.110.74):
In Reply to: M Farmall Lift Capacity posted by Rob Maloney on April 27, 2011 at 10:26:56:
An M's belly pump puts out around 800PSI if it's in excellent condition.
There's a member on here who, IIRC, lifted a C-sized tractor with his Saginaw hitch on his H, which is like 3000lbs.
With two 4" cylinders, you should be able to lift so much that you'll break the tractor.
Hydraulic pressure gauges are fairly inexpensive. Harbor Freight sells the gauge in their stores for less than $20. All you need is a Pioneer male connector and a bushing to adapt the two together.
