Re: 53 super h
Posted by sflem849 on April 28, 2011 at 05:45:57 from (69.197.84.78):
In Reply to: 53 super h posted by bbaro on April 27, 2011 at 13:11:38:
You can hook chains to the low side of the frame rails and pull out. That is what I do. You could also bolt short chunks of chain to the frame rails. You could also use a clevis in the front. You could also get/make a plate that bolts onto the front.
The load rating on those hooks gets cut in half when you have a lateral pull on them. That makes them not big enough to be legal.
