Re: Farmall 200 Fast Hitch
Posted by farmallhal on April 28, 2011 at 07:39:04 from (76.4.171.41):
In Reply to: Re: Farmall 200 Fast Hitch posted by LRRifleman on April 27, 2011 at 20:10:03:
The spacers I have are 12.75" long and 1.25" wide made from 1/2" thich steel bar stock. There is a 2" long 1/4" diameter roll pin 11/16" from one end. There is another 1/4" diameter hole 2" from the other end which accepted a clip which are very rare and I've never seen one. Both of these holes are drilled through the 1.25" leg of the spacer. I believe with the roll pin centered it is retained by the receiver of the fast hitch but I've never had an occassion to use them. In the absence of the noted clip I think you could secure it in place with a plastic tie strap if you desired. I don't think the spacer can be lost as long as an implement is on the tractor. I don't know about aluminum but since it's function is truly a spacer would probably be at least worth a try but they might wear quickly with movement of the prong in the receiver. My email is open if you need additional info, Hal.
