Posted by Jim Becker on April 28, 2011 at 11:16:39 from (173.57.144.251):
In Reply to: fuse posted by Finnbair2020 on April 27, 2011 at 16:58:17:
The original fuse call out was 20 amps. The fuse needs to be large enough to have some capacity left above the initial surge when the lights are turned on. Otherwise, they would blow when there was no need.
The 1133 bulbs were rated 32 cp which is considerably weaker than 35 watts. Some of the later sealed beam lights were 35 watts but by then the charging system had been beefed up. The original cut-out systems only charged 9 - 11 amps after they warmed up, which was marginal on keeping up with 3 lights. While cold they would charge a little more.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
