Re: Busted block on 140 Farmall
Posted by Jim Becker on April 28, 2011 at 11:18:33 from (173.57.144.251):
In Reply to: Busted block on 140 Farmall posted by Jimmy Robertson on April 27, 2011 at 06:44:48:
The 140/240 version of that engine had some substantial changes from the earlier versions (cooling system). You don't want to cross between those versions if you can avoid it.
