Re: SUPER C C-123 Crankshaft pulley removal
Posted by farmallhal on April 28, 2011 at 15:53:49 from (76.4.171.41):
In Reply to: SUPER C C-123 Crankshaft pulley removal posted by Joe P. on April 28, 2011 at 14:12:42:
Joe, Search the archives as there are several articles and pictures of a puller that can be made to remove the pulley. There is a really good one by Keith in Oregon when he restored the Super C he did with his son Shawn. Forget the three jar approach or you most likely will be looking for a new pulley. You need to fabricate and few steel pieces for a puller along with some all thread rod and use a hydraulic jack to remove that pulley. To put it back on the tractor you need to heat the pulley in an oven for some expansion as that is what holds it on - a very tight press fit. Good luck, Hal.
