Re: SUPER C C-123 Crankshaft pulley removal
Posted by CNKS on April 28, 2011 at 17:28:50 from (216.144.104.128):
In Reply to: SUPER C C-123 Crankshaft pulley removal posted by Joe P. on April 28, 2011 at 14:12:42:
You need a bearing seperator behind the pulley to keep from breaking it. The hydraulic jack mentioned is probably easier, but not absolutely necessary, a puller will take it off. To reinstall, you do not need to heat it if yours has a threaded hole in the crankshaft, just tighten a bolt.
