GWMiller said: (quoted from post at 12:19:51 04/28/11) I have a 460 that I am putting a loader on. The hydraulic couplers in front (that the culitvator use to plug into) are shot.... like rusted solid and all the ball bearing are gone shot. I figured I could just put new couplers on but I then realized that it was 5/8 threading. So I went to my hydraulic hose guy buy he couldn"t find any reducers in stock. I did however find the right reducer from 5/8 down to 1/2 in brass at the local hardware store. It has a much thicker wall than those damn steel lines that run under the seat to run the fast hitch. Will those brass fittings handle the pressure?
Thanks
GW Miller
Brass adapters made from CA360 Brass with rolled threads and one-piece design are rated up to 2000 PSI.......great for air/water -low pressure apps. They typically are available in SAE 45 degree, JIC 37 degree, Hose Barb, compression, poly-flow, pipe, inverted flare, and poly-push fittings. This means you will be able to find brass that will fit your hydraulic app.....but will it work?
Steel adapters both forged and straight one piece design rate to 10,000 PSI. nuff said.
This post was edited by 1950whiteC at 23:39:28 04/28/11.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
