Re: Return line on belly pump system
Posted by mkirsch on April 29, 2011 at 05:13:42 from (64.80.110.75):
In Reply to: Return line on belly pump system posted by sflem849 on April 28, 2011 at 19:50:12:
Your friend who is insisting that the top hose needs to be hooked up is correct.
Manure spreader endgates need down pressure to hold them closed. Wet sloppy manure will cause the gate to float up and open if it's only hooked up to a one-way system.
Your friend is still misguided, though.
Just humor him. Hook the second hose to the fill pipe.
When the spreader gate won't stay closed, maybe you can explain the difference between one-way and two-way again, and he'll understand.
