Re: SUPER C C-123 Crankshaft pulley removal
Posted by mkirsch on April 29, 2011 at 05:33:35 from (64.80.110.75):
In Reply to: SUPER C C-123 Crankshaft pulley removal posted by Joe P. on April 28, 2011 at 14:12:42:
You can get it off with a big two-jaw puller, a bearing separator, and an oxy-acetylene torch to heat the shank of the pulley.
You're going to need a new seal on the front cover anyway, so why not use some heat so you aren't stressing the bejeezus out of everything.
Like others have said, DO NOT pull on the pulley itself with the puller.
Once it's off, clean the shaft and the inside of the pulley. It'll reinstall easily.
