Re: purchasing voltage regulator for pos or neg system
Posted by Bob on April 29, 2011 at 07:01:17 from (64.255.159.192):
In Reply to: purchasing voltage regulator for pos or neg system posted by Ellis Kinney on April 29, 2011 at 05:36:58:
The reason MECHANICAL "vibrating contact" regulators are SOMETIMES polarity-sensitive is the material(s) the contact points are made of.
MANY of the regulators I've seen these later years are NOT marked as to a specific polarity.
To save money, sometimes only one contact point of each pair is made out of "the good stuff" corresponding to polarity. In other words the upper contact in a regulator intended for (-) ground or the lower contact in the same type of regulator intended for (+) might be the most likely to erode and pit, so it's made of better stuff. (What the "better stuff" is, I don't know, copper/silver/tungsten maybe?)
If you use the regulator on the polarity opposite of the one it was intended, it WILL work, at least for a while, but contact wear will be more rapid.
Of course, ELECTRONIC VR's are a different matter and, likely, all the smoke will be let out if connected to the wrong polarity.
