Re: melted battery terminal clamp
Posted by K-Mo on April 29, 2011 at 15:34:48 from (67.55.164.37):
In Reply to: melted battery terminal clamp posted by P and R Pete on April 29, 2011 at 15:20:45:
Failed connection. When the connection breaks down the result is resistance. When high starting current passes through the resistance the result is heat.
One way to check for weak battery cable connections is to check for hot spots while cranking. Be careful not to burn your fingers.
K-Mo
