Re: purchasing voltage regulator for pos or neg system
Posted by Central Illinois on April 29, 2011 at 17:58:09 from (75.106.119.170):
In Reply to: purchasing voltage regulator for pos or neg system posted by Ellis Kinney on April 29, 2011 at 05:36:58:
Either way just don't forget to make for sure the ignition coil is wired correctly. On a negative ground system the - post goes towards the distributor and the + post goes towards ignition. On a positive ground system they are reversed. If you have electronic ignition then make 100% sure your polarity is set for whatever kit you have. I have converted an M to 12v negative ground and an H to 12v negative ground with electronic ignition. One last thing is if converting from positive to negative ground then don't forget to switch the leads on the ammeter or it will read backwards.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
