Re: 806 brakes still lock up
Posted by pete 23 on April 29, 2011 at 19:30:11 from (74.44.100.190):
In Reply to: 806 brakes still lock up posted by Dave from MN on April 29, 2011 at 04:30:25:
What I am getting at is that it is possible to have some flow out of the bleeder even without pedal being pushed. What you need to determine is if when opening the bleeder do the brakes drag. If they do not drag with bleeder open but do drag with bleeder closed then your problem is in the brake valve. The normal adjustment on those tractors was to actually have a slight amount of tension (in other words pulling the spool out of valve) so the brakes would be responsive quickly but not develop enough pressure to over come the return springs in the brake.
