Re: melted battery terminal clamp
Posted by Buzzman72 on April 30, 2011 at 05:23:03 from (74.129.205.211):
In Reply to: melted battery terminal clamp posted by P and R Pete on April 29, 2011 at 15:20:45:
Resistance generates heat...and corrosion is the most common cause of resistance in these situations.
6V system requires twice the amps to do the same work as 12V [volts x amps = watts, and that's what does the work], and to carry those amps well, larger gauge cables are a MUST.
If it was me, I'd be seeking out an old-style braided ground strap type cable.
