Re: no spark-Farmall H
Posted by Wayne Swenson on July 29, 2000 at 22:21:25 from (206.9.159.122):
In Reply to: no spark-Farmall H posted by George Wilson on July 29, 2000 at 10:29:17:
Are you sure that a wire or connection is not touching a metal ground at some point in the primary ignition system??
Look in the distributor where the wires are attached to the points; your troubles began after the "tuneup" so you should recheck your wiring before condemming the coil.
Post A Followup
: Re: Re: no spark-Farmall H
