Re: wide front end
Posted by Harold H on April 30, 2011 at 16:41:43 from (68.59.252.155):
In Reply to: wide front end posted by James K on April 30, 2011 at 07:54:22:
The wide front and the tricycle front are easily swapped. However, if you are used to the tricycle front, the tricycle front is much more manuverable than the wide front axle. I personally would not recommend a wide front axle on a C because of the manuverability.
Harold H
