Posted by DuvoBros on April 30, 2011 at 19:28:21 from (67.142.130.48):
In Reply to: Re: Farmall A shutter posted by Tom Fleming on April 30, 2011 at 18:09:11:
Tom,thank you for the info. The shutter and control rod and control lever are in very good original working condition. yes it does have the temp guage that mounts to the governor. yes,lower water pump..I just got the tractor and was gonna scrap it due to needing rims,tires,hood,grill due to being rough..Its a 1948.Now,you say dual fuel? Was this tractor to be run on kero also? The manifold and carburator look to be the same as the one i have on my 43 farmall B and 53 A. I also have another odd farmall A that has a sticker A-cultivision that i wish i could talk to someone about...Has a wierd engine number (FAAMG) and the serial number brings it to be a 1953...The serial number and engine number do not match. The tractor sits high at the front and rear axle..It doesnt sit as high as a farmall AV.. This tractor also has a hydraulic,and the serial number starts out with a FAA- What is the (-) dash mean and what would the MG above the engine number mean? Is it also a super A or just A cultivion? Thank you so much if you know what im talking about.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
