Posted by SouthernFarmall on April 30, 2011 at 20:04:58 from (76.4.24.140):
In Reply to: Super C Quit posted by Wi-Ed on April 30, 2011 at 19:25:31:
Take your drain plug out and make sure you have gas inside the carb. After this, take a ball peen hammer or equivalent and tap the side of the float bowl in the carburetor. If that doesn't do it, then make sure you have spark where and when you need it. This means checking plugs, wires, breaker points, and anything else in that system. If you still can't figure it out, take the carb apart and make sure the float is not stuck and there is no crud in the jet. First blow it out with an air compressor, then soak it in carb cleaner, and finally blow it out again before reinstalling. While you are in the carburetor, go ahead and check the gaskets and clean it up real good. I hope you figure it out, SF
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
