Re: Farmall H starter
Posted by SouthernFarmall on April 30, 2011 at 20:29:17 from (76.4.24.140):
In Reply to: Farmall H starter posted by Chris Sw on April 30, 2011 at 20:21:02:
The only time I have heard of using anything 8 volt was to give a 6 volt system a little more "oomph". I have never heard of an actual 8 volt system before. I guess you learn something new every day! Anyway, you should definitely enlarge the battery cables. There also might be something drawing charge. If the lights were not wired correctly, they can run the battery down, even when off.
Good luck, SF
