Re: Farmall 240 Gas Tank Removal - Suggestions for Success.
Posted by horsepoor on April 30, 2011 at 20:44:35 from (208.124.126.217):
In Reply to: Farmall 240 Gas Tank Removal - Suggestions for Success. posted by pete 23 on April 30, 2011 at 07:21:20:
I took mine off my Farmall 240 2 years ago to seal the tank. Had a pinhole. Take the side panels off the hood. Take the radiator cap, gas cap, muffler, and air breather off. Take the hood off. Take the sheet metal off above the tank. It is separate from the hood, but the hood overlaps the bolts for this piece. There will be a small piece of metal under the touch control handles held on by two sheet metal screws that needs to come off. Now before you move anything on the gas tank cover, take all the screws off the instrument cluster along with the white corner pieces and sides. Need to remove the panel by the gear shift too. You should be able to take the gas tank cover off at this point with some maneuvering of the instrument cluster. There are four bolts holding the tank down. The choke cable runs thru some clamps on the tank bolts, so don't loose them. It sounds worse than it really is. I would replace anything like the choke cable at this point if you need one because you don't want to do this again for stuff like that. Good Luck,
-Horsepoor
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
