Posted by primerk5 on May 01, 2011 at 05:40:04 from (71.248.97.134):
In Reply to: Farmall H starter posted by Chris Sw on April 30, 2011 at 20:21:02:
I have the exact same problem. Only difference is mine crank slow but will almost always start.
I've had this issue for years. I've had my starter looked at and my generator looked at, and they both test good... My H ran and started great when I got it. I replaced the wiring harness and the regulator and then I couldn't get it to charge or turn over fast. Two regulators later I fixed the charging problem. I wish I had saved the regulator that was on the tractor instead of throwing it away at tear down. Only thing I can think is that mine must have been 8 volt when I got it.
Here's a question fo you. On your S/N plate, do you have an X1 at the end of your S/N? That would mean high compression from what I've read. I believe that is the issue with my tractor. The standard Starter dosen't have enough oomph at 6 volts to turn over that engine. I can't even hand crank my tractor. And to my knowledge it has never been rebuilt.
This post was edited by primerk5 at 05:41:36 05/01/11.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
