Re: Farmall H starter
Posted by John M on May 01, 2011 at 06:20:22 from (67.231.169.173):
In Reply to: Farmall H starter posted by Chris Sw on April 30, 2011 at 20:21:02:
1 gauge cables are borderline, IMHO, get 00 cables for all 3 starting wires, new HD starter switch, and make sure every connection is clean, then clean them again. Why did you change it all, if it aint broke, dont fix it!!
