Posted by MadMax (TX) on May 01, 2011 at 06:46:59 from (70.133.156.176):
I have a 2400B industrial tractor which is suppose to be the same as a 454 that I have some hydraulic issues with. Whenever I attach a heavy implement like a 1000 lb plow and begin to lift the implement my tractor makes grinding noises similar to when you shift gears at high rpms. After the implement begins to lift it quits. Also after plowing and the engine is hot, I really have to rev the engine up to high rpms to lift plow again. Haven't been able to get much advice from local repair shop. I replaced the pump and relief valve last year. Any suggestions would be appreciated.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
